Just can't recall. Is it best to put Waxoyl into the frame holes and spaces before, or after, painting the outside with POR 15. If Waxoyl is messy, I don't want to have to prepare the frame all over again. thx
POR-15 needs a clean surface (typically Marine Clean'd). Once its dry, its almost like a ceramic, so not much will get through it. I can't see trying to put it on top of waxoyl or what advantage there would be to putting it on top.
POR-15 first, then Waxoyl. As mentioned, the prep work for POR requires a thoroughly degreased, acid etched, phosphate coated surface for adhesion. Waxoyl would definitely come later.
KVH, make sure to put some plastic wrap or such down on the floor, or you'll be sliding in the waxoyl drips for awhile! /ubbthreads/images/graemlins/grin.gif
Jeff
[ QUOTE ]
Jeff
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif
Also a good idea when painting with the POR15 to avoid giving your floor the "Dalmation dog" random spots everywhere look.
Agreed. Greeting business associates with black streaks across your face ends up leaving the wrong impression, and explanations sound lame no matter how hard you try.
