2wrench
Bought a new starter from Roadster Factory for my
'74 TR6. Isolated car battery. Installed starter. Set
negative battery cable on post to reconnect and heard a big POP!
Negative battery post now has a significant dibit in it.
Obviously, something is wrong.
This new starter had one post available that seemed
to be the obvious location for the hot wire, so I put it there. The ground wire was connected on a paddle and so it seemed could only go one place, so I put it there.
Wires were covered by a blue plastic cap/sheathing and I never removed nor looked under them. They face the
engine side and I thought theses wires were simply protected
from the engine heat.
I surmise I hooked the wires up wrong. Can someone please
help? Thanks in advance.
P.S. Did not come with installation instructions. Seemed pretty straight forward.
Hi Guest!
