Help with torquing bolts
Phototone
When torquing the bolts on such things as a flywheel, that has a plate that you are supposed to bend down over the flats on the bolts to keep them from unscrewing, if your torque setting results in the bolt head not presenting a flat for the plate to be tapped down on, do you torque a bit more, or do you back off a wee bit to get the flat on the bolt head positioned right?
NEVER slack it off. The tabs are mild steel, they can be bent on / over the corner of a hex head from two directions.
You've posted this in the HELP section for questions regarding FORUM issues. Try posting it in the "Restoration & Tools" or a marque-specific sub-forum for more visibility.
Phototone, you posted your question in our "Forum Help" forum, which is meant to ask questions specifically about how to navigate this site. I am moving your post to our "Restoration and Tools" forum. (If you're reading this you are now in that forum.
Torque to specs, then bend the tabs over the bolts. It is used for a preventive movement of bolt.
