TR6 Help with rebuilding TR6 heater system please
ichthos
Hello,
I had planned on working on my heater a while back but got sidetracked on other car projects. My heating system is in bad shape, and I plan on going through the entire system next. I would also like to powder coat the heater box. I need to know who is my best source for parts, and especially where I can buy seals for the heater box. Also, does someone sell the decal that goes on the heater box? I seemed to remember Paul talking about doing this, but I lost most of my information due to my computer being hacked recently. Any help on where to buy parts or help in the rebuilding process would greatly be appreciated.
Kevin
DNK
Kevin, Check Paul's and Bobby's sites.
I PC'd my box many years ago.
Most of the seals get from the big box stores.
Gliderman8
:iagree:
I just bought foam weather seals and it works fine.
I
ichthos
Don, were you able to find the two decals that go on the heater box? Where did you order your parts from? I tend to like to order from a place in PA you told me about, but I sometimes find it difficult to navigate to find parts on their site. Thanks for the tip, Elliot. Mine are almost gone from mice. Hopefully I have enough left to figure out what I need.
Kevin
DNK
ichthos said:
...I tend to like to order from a place in PA you told me about, but I sometimes find it difficult to navigate and find parts on their site.
Kevin
TRF??
DNK
Kevin, what parts do you need . There really isn't any parts per se in thee.
I
ichthos
Yes, TRF. Couldn't remember if I could use company names on the forum. I am not totally sure what I need because I am in Ohio and don't have access to my manuals or catalogs. I won't get a chance to take things apart for another month either.
Kevin
DNK
As long as you don't throw em under a bus it's fine.
Gliderman8
Kevin- You are probably referring to the "Smiths" decals on the side of the heater box. I did without them as no-one will see them anyway!
tomshobby
Hi Kevin,
Made them as a favor for a guy that has done some favors for me.
I have been trying to find the artwork I made for them but have not had any luck. Too much stuff in my hard drives.
They are vinyl stick on decals like the originals.
Only a couple left but if you pm your address I can help you out with a set.
I PDWA switch rebuilding help Triumph 12
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
