TR6 Help with 69 TR6 parts, part 2
ichthos
I also need to know what this part is. My car was mostly dismantled when I bought it, but this part was in the proximity of the kidney pad. Anyone know what this is and how to install it? Thanks in advance for your help, Kevin
DNK
It's kind of dark.
Use a different back drop (section of floor)
Different angle?
Don't you use Photobucket?
If you have a problem with it E mail me the shot.,if no one gets it.
mallard
It looks like the back cross support for the kidney pads. It connects to the back of the pads and lays across the trans cover.
TR4nut
I'm with Keith. But a kickstand is a good answer!
mallard
If you got the TRF green TR6 catalog page 415 has a good picture of how it's installed. If you don't have the catalog I was wrong about it mounting to the back of the pad. It should be mounted to the center of the pad. The longer leg goes on the passenger side. The top hole should have a rubber buffer in it that goes against the heater box. Also the leg should go up.
DNK
That would explain why I had no idea.
Thieves stole my cars kidneys and left it in a tub of ice
Gliderman8
:iagree: Yep....Keith has it right
TR6BobNF
Can you post the length? I need to make one and TRF wants $24.00 plus shipping. I could wing it but the right measurement would be nice. Thanks.
I
ichthos
I could take measurements, but would you like me to trace it or photo copy it and mail it to you? Might be a little more accurate.PM your address if you are interested.
Kevin
I TR6 Help with TR6 parts please Triumph 3
D TR6 Help with tr6 engine diagnosis Triumph 11
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
7 TR6 help with tr6 hardtop value Triumph 5
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
B TR6 Help me choose new wheels for72 TR6 Triumph 7
I TR6 Distributor help on TR6 Triumph 5
I TR6 TR6 fender removal help please Triumph 10
I TR6 TR6 grill emplem help please. Triumph 16
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
bash TR6 TR6 electrical help Triumph 11
I TR6 TR6 performance help Triumph 10
I TR6 TR6 window weatherstripping help please Triumph 1
I TR6 TR6 windscreen rubber seal help Triumph 2
I TR6 Help! melted wire in my TR6 Triumph 23
I TR6 TR6 courtesy light wiring help Triumph 26
I TR6 TR6 fuzzy seal clip help please Triumph 16
B TR6 Help with removal of TR6 crankshaft end bolt! Triumph 11
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
I TR6 Need help on 69 TR6 glove box info Triumph 0
I TR6 TR6 heater removal help please. Triumph 5
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
I TR6 TR6 kidney pad installation help please Triumph 7
O TR6 1971 TR6 Starter Help Triumph 1
I TR6 TR6 bonnet help Triumph 7
T TR6 TR6 pricing help Triumph 16
G TR6 TR6 Help needed Triumph 13
I TR6 TR6 luggage rack - repair help Triumph 13
I TR6 TR6 PDWA switch help please Triumph 10
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
I TR6 help with TR6 windshield wiper arm removal Triumph 6
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
I TR6 Help with rebuilding TR6 heater system please Triumph 19
I TR6 Carb help please for 69 TR6 Triumph 14
I TR6 TR6 gas line leak - please help Triumph 15
I TR6 TR6 oil sending unit thread size help please? Triumph 12
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
V TR6 Help w/ toe dolly TR6 Triumph 14
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
I TR6 TR6 aluminum ring restoration help Triumph 6
TR6oldtimer TR6 TR6 accelerator linkage help needed Triumph 9
