Doc, as a point of fact, Many times the hammer is the correct tool. However, selection and application of the CORRECT hammer is what separates "the men from the boys" Should you ever need to know (because this is given out on a strict need to know basis), I will share the secret to using an air hammer to change the Jag XJS/XJ6 ac expansion valve. Without breaking the evaporator...
