bighealeysource
The overdrive on my 56 100M was working perfectly and then out of nowhere it stopped. Have checked all the electrical connections per the trouble shooting guidelines in the works manual as well as articles from Roger Moment. Even put in a new throttle switch since the existing one was the original. Get no response of the desired solenoid clicking but what I can hear- when you simply switch on the ignition,press down the gas pedal and move the gear shift to the right when in 3rd or 4th gear - is a very slight whining like the solenoid itself is trying to move the plunger. Faint but there when you move the gear shift. I am thinking this must be the solenoid and guess I get to remove the tranny tunnel and check it out. From everything I have read on this subject seems like if the electrical tests do not get any results then must be the solenoid has given up the ghost after working just fine the other day. Any other advice ?
Thanks,
Mike
Thanks,
Mike
Hi Guest!
