TR3driver
Great Pumpkin - R.I.P
I'm with Randy, I don't believe the pumpkin itself will fit between the frame and the body. In any case, I've always done it by the factory method, which is to remove both backing plates, slide the housing to one side until the opposite tube will drop below the frame, then slide it the other way. On my TR3, I don't even have to drop the exhaust.
The shock links don't have to be disconnnected on a '3, as they attach to the plate under the springs (which you can just leave dangling).
Just put my axle back in night before last. Taking longer than expected, but I'm finding some other things to attend to (like the leaking shock, new brake lines, rebuilding one of the cylinders, etc.) In retrospect, I probably should have installed the new hard lines first, rather than waiting until after it was in the car.
As far as finding a used one in decent condition (I would/did still replace the seals and clean as much as practical), the thing to look for is a wrecked car or an abandoned restoration project. I sold the one from my wrecked car last week, so I'm using one that came with a restoration project many, many years ago. As I mentioned before, I think Ted Schumacher got one of the other axles that came with the same project.
