1979 midget: I am interested in replacing rear brakes and fronts as well. I took a look at the rears first and had a couple of questions:
1. where is the adjustment wheel on the rear drums? Also, after removing the tire and rim I noticed a couple of phillips head screws that appeared to hold on the drum. Any tips on getting those out? Also, there was another phillips head that was not holding on the drum , but rather under the drum. It didn't seem to want to move either.
2. I moved to the front brakes. I noticed that the caliper was not similar to what I have seen on more recent autos. When I loosened the two outside bolts that looked like they would let me remove the caliper to get at the pads...brake fluid started to drip our a bit...I quickly replaced them and tightened them back up. So..how does the caliper come off? Where are the caliper slides that are usually found on the backside of the caliper? How do you remove the caliper to get the pads out?
Thannks!
Thannks!
