boxfullofyertoys
Hey everyone!
I had some time this weekend to get back into the garage and start working on the rear end. I'm basically removing the rear suspension and axle, and then cleaning it all up and replacing all the worn out stuff (bushings, shocks, springs...etc.). I snapped the threads on one of the rebound strap mount points a while back, so I'm replacing the whole rear end housing as well.
I've managed to get pretty much everything disconnected, however I can't seem to get the plates that clamp to the axle to descend off of the U bolts so I can pull the axle out.
Does anyone have any tips/tricks for getting that stuff separated? It's so frustrating to be super close to having all of that stuff removed and be hindered by a few U bolts!
I'm also having trouble removing the small links from the rear shocks...any tips for getting those apart as well?
Thanks!
Thanks!
