help on bolting on an isuzu trooper II starter
abe
Hello anyone,
So i bought my isuzu trooper II starter frame/part number 17155 (the one that bolts right on) for my 1958 Austin-Healey Sprite Bugeye (948cc A series). I eye balled it to compare it against the original starter. all looked good and similar like it would work without trouble. Unfortunately i'm having trouble "bolt"ing it on? I have a clearance issue in which the starter's flange and bolt that holds the solenoid in place is hitting up against the engine where the oil pan/engine block/and transmission meet.
Has anyone ever tried this or is it just rumor that it bolts right on? I think I might have to either return the starter or get a machine shop to duplicate the original with enough clearance. any comments? please hit me up, thanks
abe
Hi Abe, Most of us up here have the big Healeys and are not that conversant with the small ones. However, there is a forum below titled Sprigits and those fellas there can certainly beam you up.--Keoke
oh, right. I didn't see that forum section for spridgets. thanks!! still new at this forum. ha ha
Abe: I'm not familiar with Sprites, but I recently installed a Japanese-made starter on my 3000 (perhaps the same manufacture as yours?) and also ran into fit problems; mine was bolluxed up with the oil filter/fuel line/oil pan flange as I recall. The trick, I found, was to loosen the base from the motor unit (easily done, only 2 bolts as I recall) and then rotate the base vs. the motor housing to select the option that would clear the fit problems. Took a little trial and error but it eventually was solved once I figured it out. Note that even then the clearance between the cable terminal and the block was somewhat close, so I was sure to put a rubber cover over the terminal as a precaution. Good luck!
The aftermarket starters such as this one from APT have multiple mounting holes for the starter nose clocking. See attached pics.
