doughairfield
We must be looking at different photos, Don. I'm looking atDNK said:Randall, I'm no 4 expert but those look like push connectors to me.
I would guess that explains the missing wire then. Whoever installed that early control box just forgot to connect the wire to the dash lamp. The red light should come on as soon as you turn the key on, then only go out once the engine is started and the generator is working.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Question, I noticed that if I rev up the engine to about 3500 the low power problem seems to go away. Wouldn't that lean more towards a generator problem as getting it spun up fast enough would produce enough power to run the engine cleanly, and at low speeds it was not generating sufficient power?[/QUOTE]The regulator has a resistor that supplies some field current to the generator all the time, basically just enough to operate the ignition at higher revs (when the generator output is higher). At least in my experience, generator failures tend more towards "all or nothing" (though partial failures are certainly possible too).doughairfield said:The red light does not come on at all, never has.
doughairfield said:I have not checked the fan belt, that is a good suggestion. What did you use to gauge how tight it should be?
