I'm rebuilding the brake master cylinder on my 67 E-Type and need some suggestions for removing the piston assembly.
I have removed the spirolox circlip and the circlip as shown in the manual Fig. 16, Supplementary Page L.18. The piston moves smoothly in the bore and bearing. At this stage, the manual says "The piston assembly, complete with nylon bearings and rubber seals, can be withdrawn from the cylinder bore." The piston assembly does not come out easily; in fact, I cannot get it to budge with the normal pulling or application of air pressure applied at the outlet adapter. I have not applied heat and I have not applied air pressure to the inlet. I also have not checked to see if the nylon bearings can be purchased in case I destroy them on removal. Any suggestions?
Billca
Billca
Hi Guest!
