I hooked up my courtesy light wire to the switch on the right side. (I stll can not find the driver side courtesy light wire - as I mentioned in a previous post, the PO may have cut the wire somewhere in the harness and rewrapped it). The courtesy light is currently not hooked up. Last night as I was driving, smoke started coming from under the dash. The wire melted from the passenger side switch all the way to the driver side plug. A white wire connected to it also melted. What would cause this? I am also wondering what amp fuses should be in the fuse box. They are not burning out when I have electrical problems. This is the only thing electricall not working in my car a the moment. Any help is greatly appreciated.
Kevin
Kevin
