G
OK, set my #1 cylinder at TDC, marked my crank sprocket and cam sprocket to line up, even daubed some red paint (actually finger nail polish) to keep the chain and sprockets in the same spot, then installed the new cam in the same exact relation to the crank. Now I need to see if the new cam is close enough. Should I go ahead and put the new lifters in and install the head? Wouldn't this make it easier to dial in the new cam? This way I can watch the valve train work and set a dial indicator somewhere in there to check my cam settings. I do have an adjustable Kent sprocket on my cam, although I am slotted all the way to one side on it (guess I could jump the chain a tooth to get the slot to the other side if need be).
Starting to burn out a bit, too many other pressing things in my life right now. Really want to start enjoying my baby again soon to blow off steam.....
