jessebogan
Hello Folks,
I am overhauling a BT7 trans for a friend. I am awaiting some parts and a service manual CD, but they won't be here until next week. Teardown was going great until I get to the point of removing the mainshaft from the case. It seems to me that I need to remove the "bearing carrier" from the rear of the trans case.Second gear won't clear the boss for the reverse gear shaft. So, could one of you fine folks take a look in the shop manual and tell me what the pocedure to remove the bearing carrier is? I don't see a set screw or anything like that, but it is the things you don't see that breaks things. If that is not the plan, could you advise me on the proper method?
Thanks much in advance
