DNK
When testing my TPS I wanted to check the ground resistance.
I hooked 1 side to the ground wire on the TPS and one to a body ground to the engine.I'm showing .0021.
The question here is ,Is it OK not to be at 0.0 or does this show some point in the wire that it might be a little screwy between the switch and the computer to the ground.
Anything else I should test to verify?
