Ok guys, here is my problem..My brake lights didnt work, so I took out the old brake light switch, and it turned out the old one is bad (the center pintle piece was rusted and didnt move)..I ordered a new brake light switch, and when I installed it, only the passenger side brake light works..
So, this is the problem now: With the parking lights off and the brake light switch on (i.e. the center pintle not pressed in), the passenger side brake light is on (bright) and the driver side light comes on (but dim).
With the parking lights on and the brake switch on (i.e. center pintle not pressed in), only the passenger side light becomes bright and the driver side light totally shuts off. When I press the center pintle in (i.e. brake switch off), the rear parking light go normal (i.e. both become dim).
What can be the problem??? Faulty brake light switch? It seems it doesnt matter which way I connect the switch either, is that correct? I checked all the connections and everything seems ok..Im really confused!
