MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill?
martyc
We're loving the new (to us) MGB! One thing that bugs me is that when coasting downhill with closed throttle (i.e. engine braking) there are often "pops" that sound like they're coming from the exhaust.
It's a 1973 that has had the dual SU's replaced with a Weber DGV by a previous owner. It also looks like it has a "performance" exhaust and headers from what I can tell, so it sounds a little different than a typical B in general.
Any suggestions on what the "pops" could be? Recent work since I've owned it includes a valve job by a reputable shop, but I believe it "popped" prior to that.
Perhaps this is normal and I'm paranoid?!?!?!
Thanks, in advance, for any advice.
jlaird
The pop is caused by extra fuel burning in the exhaust system when you let it run on compression down hill. Might be just a bit rich.
Dave Russell
Yoda - R.I.P
Re: Help: 73 MGB w/ Weber DGV Carb - Popping Downh
That is usually the cause. It is normal to have excess fuel during deceleration. However, there should not be enough oxygen in the exhaust system to support combustion of the unburned fuel. The popping is often caused by exhaust system air leaks which supply the additional oxygen that is needed for combustion of the excess fuel.
Nunyas
Is the smog pump and air injection manifold (and the rest of the emissions equipment for that matter) still in tact?
If so then you might have a Gulp Valve that isn't letting enough air into the intake manifold to burn the engine braking fuel in the combustion chamber, and the unburnt fuel is going into the exhaust and igniting with the air being injected by the smog pump.
Platinum
You guys mean t' tell me that when I lift in a tunnel with the Elan at 6.5K and four foot FLAMES come explodin' outta the blat pipe I'm ~really~ not P.C.?!?!
...I guess I gotta apply fer them "carbon offsets" now...
RATS! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
jlaird
Or the track car lifts at turn one at 10.5K and you get two foot flames and the crowd goes ahhhhhh that it is wrong. hehe.
Nunyas
I like the popping in my car's exhaust... only thing is if it's too forceful it'll clear the catalytic converter out. hmmmmmmmmm... /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
no no no no ... I still have to pass emissions tests!
Camshaft
Rest of US > California /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
martyc
martyc
Nope...it's de-smogged. /bcforum/images/%%GRAEMLIN_URL%%/sick.gif
MGB_80
Mine is really loud when it pops...probably because i have a straight pipe on it /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
B MGB-GT Need help with MGB GT rattle MG 0
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
R MGB Turn signal help 67 MGB MG 2
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
Tinkerman MGB 1980 MGB wiring diagram help MG 6
M MGB Help! MGB Baulk rings MG 2
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
M MGB My 1980 MGB [Need some help please!] MG 28
S MGB-GT need help on an mgb gt 1975 MG 3
S MGB MGB syncro help MG 10
bcliff MGB MGB w/Isuzu V6 need help MG 1
eschneider MGB MGB Piranha / Newtronics help!!!! MG 6
W MGB-GT MGB Ragtop help MG 10
bighealeysource MGB Help needed from new 65 MGB owner MG 11
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
Scott_Hower MGB Help establishing MGB value... MG 16
kurts100 MGB Can you help verify this is a 1964 MGB MG 12
PAUL161 MGB 70 MGB Dilemma. Questions, Questions! HELP! MG 11
53caddy MGB 1973 MGB help Please MG 67
P MGB 63 MGB Overheating Help!! MG 18
N MGB My MGB Won't Start--Please Help MG 36
PAUL161 MGB HELP! 72 MGB coil springs MG 5
W MGB MGB Emission Control I Need Help Please MG 6
Steve P. MGB-GT Help:'70 MGB-GT running hot MG 4
E MGB help! fuse replacement 77 MGB MG 5
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
M MGB MGB Steering Rack Help MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
