Hello from the newest newbie
spankyway
I have just be come the proud owner of a 75 MGB that did not cost me a thing! I got the car off a tradefrom a none running 75 Goldwing that did not cost me anything!! It came from a friend that I gave advice to on how to paint his trike!!! Anyway I now have a running and driving 75 MGB that I am already having fun with.
I do have some questiond though, The red light (The alternator light?) on the dash stays on while the engine is running, any thoughts. Also the rear blinkers and back up lights do not work. And last but not least is there anyway to put a good generic choke on these cars?
Steve
jlaird
Check wireing grounds.
Rear lights are grounded inside the trunk near the tag mount.
On my car, I had the same problem with the rear lights, I had to clean the bulb sockets, and replace the bulbs in the reverse lights.
I'm not sure what the red light indicates. Different dash setup than mine.
martx-5
Welcome aboard Spanky.. /ubbthreads/images/graemlins/savewave.gif
The price sure was right! I'm sure the MG will provide you with lots of fun moments.
As far as the alternator idiot light goes. That comes on to indicate the the voltage coming from the alternator is less then that of the battery...in other words, it ain't charging. Check the obvious first, like a loose belt and connections to the alternator. If that checks out OK, your alternator is most likely kaput. If you have a voltmeter, you can check the things yourself. At about 2500-3000 rpm, the alternator should be putting out about 14 volts with no load...electrical accessories off. If you load it up, the voltage will drop, but shouldn't go below about 13.2 volts. If it doesn't put out anymore then battery voltage, then there is a problem. At that point, best to find a local rebuilder to check it out and repair it.
Good luck with the new MG.
JTB
If the alternator is gone then consider an upgrade. Don't know what amps your stock one puts out but there is an upgrade of a Ford Fiesta alt that puts out abou 50 amps and an AC Delco (Saturn I think) that puts out 90 or so. Really makes a difference when you add things in the future that need current and just makes lights brighter when you do. The Fiesta one is a bolt on generally (I had to flat file a mounting ear a bit was all) and the AC Delco one takes a little more work but not extensive. There are some web sites around with detailed instructions.
Nunyas
looks like everyone got ya covered on the electrical bits. /ubbthreads/images/graemlins/grin.gif
For that choke, you can get a manual choke conversion from Moss Motors, Victoria British, or Tony Barnhill. From looking at the catalogs, I like the appearance of the manual choke conversion kit for Zenith-Stromberg carbs (the stock carb on MGBs that only have a single carb) the most.
Your other choke alternative is to take the carb off the car and rebuild it and the choke. From what I hear, the stock choke is not a bad unit if kept in good nick. My '76 was converted to manual choke when I got it so I'm not 100% on this, but if I'm not mistaken you need to fully press the accelorater to the floor and let it back up to activate the stock choke before attempting to start the car. No worries on "flooding" the engine doing that because stock MGB carbs have no accelorater pumps.
Anywho, I hope at least some of this info is helpful, and best of luck
Platinum
IIRC, NAPA also has a manual kit for the application... I can't vouche for the style of the knob tho. /ubbthreads/images/graemlins/wink.gif
S
spankyway
thanks guys, you have given me a lot to think about.
Steve
p.s. anybody on the list from northwest Georgia? up around Dallas or Cartersville? It would be nice to have someone close to talk with.
Platinum
*sigh*
West-central FL here, and know the dilemma.
David64MGB
Check for car clubs nearby. We have a English car club where I live with about 45 members, and this is a city of 200,000. All with cars. An amazing resource for advice, parts, and someone to drink your beer while they try to tell you why your alternator isn't working.
tony barnhill
Great Pumpkin - R.I.P
Way to go.....so, what's your final goal for all your swaps?
Platinum
"...even th' lighthouse is dark..."
Apologies: Great Lakes fever.....
R6MGS
Welcome - What a deal! An old free car is much sweeter than anything that has a price tag.
S
spankyway
I hope to get it where I can drive it daily with some reliability. I have owned a Triumph before so I know how unreliable they can be. I do drive it now and I LOVE it but my red dash light stays on while the engine is running. I went and got my free parts car the other day and I should have plenty of parts to create a real nice roadster.
Steve
Tim_80B
Hi Steve,
Free car, free parts car...and lots of free advice here. You've got it made.
I did the Ford Fiesta Alt. swap on my 80 when my ignition light started to glow continually. Nice and simple bolt on. It may be overkill but I have found that Kopr Shield from Eastwood is a great way to keep those grounds solid.
Welcome aboard!
Tim
S
spankyway
What year Fiesta alternator is that? I read about this conversion some where but cannot remember what year. I am going to check my alternator, if it is bad I will probably do the conversion.
Nunyas
1980 ... and it's the Bosche alternator. If there's any doubt or if the clerk asks ya, make sure you get the Bosche unit, even if it's reman'ed. I put one on my car last year, have been loving it ever since /ubbthreads/images/graemlins/grin.gif
timbn2 say hello to the newest [future] Healey enthusiast Austin Healey 13
regularman Hello Y'all Spridgets 3
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
B General TR Hello from Bauly Triumph 19
A Hello from new member, and car identification help request Other British Cars 9
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
regularman Hello Everyone. Ran my Midget till it locked up Spridgets 20
R Hello, new to the forum and new to Austin Healey. Austin Healey 31
R Hello all and a question for a newbie... Austin Healey 13
regularman Hello all Spridgets 25
regularman Hello to everyone Spridgets 14
S New member saying "hello" Triumph 8
Zitch Hello I'm new to Triumph Cars Triumph 65
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
Got_All_4 TR5/TR250 Goodbye TR3ATR250 Hello Got_All_4 Triumph 12
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
T New Member - Hello Triumph 15
P Hello Triumph 22
L Hello - This is my first post. Triumph 34
blackdog Long time lurker says hello Austin Healey 5
M Hello Triumph Folks Triumph 24
T British by the Sea 2010- just saying hello Triumph 11
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
J Hello Contra Costa County California MG's MG 0
doates Hello and Transmission Question Triumph 17
J Hello! anyone know of good engine conversion info TVR 16
Cabrioman Hello Triumph 74
KLUTZ Hello all... MG 21
M hello from new member Spridgets 8
L Hello again everybody. :D Spridgets 7
S A hello TVR 8
Mark_Barton Hello!... and roadside assistance recommendations? Triumph 22
G Hello again Triumph 6
roofman Hello, hello, hello British Motor Corp 12
M T-Series New 52 TD owner saying Hello MG 45
J Hello I am Jim and need a Water Pump Tonight!! TVR 1
J Hello from the triumph board - Looking at a Jag Jaguar 5
J Hello. Newbie here. Spridgets 35
MadMarx Hello -- may I introduce myself Triumph 11
judow Hello, I just lost my mind!!! Austin Healey 10
1 Wedge So it spreads... Hello, looking at TR7s Triumph 34
Monark192 Say hello to GAN1L12795 Spridgets 16
X hello all Jaguar 3
G Hello from Phoenix Triumph 8
R Delayed Hello from a new member MG 11
G Hello from a new member Jaguar 3
J Hello MG forum from a new member MG 17
C Hello, Intro/New owner. Love this car! Spridgets 11
Rob_P MGB Hello from a Newbie MGB owner... MG 16
G Hello members MG 25
