    Thanks and welcome to BCF!
Hello from Maui.Iwas a member back in the 90s from my last TR6, which I wish I had never sold.
Pego
Anybody know where the power comes from to the + on the coil?
In 75 & 6 a resistor wire was added, and remembering my older TR6 which was so much fun, ran far better, I an attempting to take my car back to earlier days.such as vacuum advance instead of retard.
All is done except the final hook up, so nervous. I also changed the coil back to a 12v 3.2ohm, i.e. full 12V running, without resistor wire.
Any offerings greatfully accepted.
Welcome to the BCF, Pego! This is the New Member intro forum where you just i9ntroduce yourself to the group. However,m if you post your technical questions in our Triumph forum you are more likely to get responses.
Cheers,
Thankyou for the ‘welcome’.
I have yet to find my way to the apppropriate (Triumph) forum.
Click on the "Forums" tab above. Then scroll down to the word "Triumph" and click that - now you will be in the Triumph forum. (Unless you are on a smart phone, in which case, tap the three lines in the upper left of the screen, then tape "Forums" and then scroll down to "Triumph."
