toysrrus said:Hey David,
Who is "TJ Motorsport"? "TADS"?
Russ
Trevor Jessie said:I drove mine to the local Healey meeting last night (I was the only one that drove a Healey), and I hit the rev limiter a few times before I knew what had happened. The new air intake system has made a huge difference. Now I have to get it back to the dyno to be sure I'm not going too lean when the hammer drops.![]()
BlueMax said:Gundy, According to BMC Special Tuning Section for the 1 ½ carbs the standard needle called for a #6, part number AUD-1006, I hope this will help on the to rich situation?
Hap Waldrop said:BlueMax said:Gundy, According to BMC Special Tuning Section for the 1 ½ carbs the standard needle called for a #6, part number AUD-1006, I hope this will help on the to rich situation?
No, Alan, thats way too rich, my MGB only uses #5, my guess for the A series street driven engine w/ twin HS4s in solid needle would somewhere around a #3 or #4.
Alan, David, sorry I ain't using those silly code names
There's a new chassis dyno place like a mile or so up the road form the shop, a couple of blocks behind Duke Sandwich Co., I'll be going there next Tuesday after lunch with Tom Buto and his SCCA Midget race to dial in his carbs and timing. If you boys want to come grab a Duke sandwich and then sit in on the dyno session, you're more then welcome, it will give you a better idea what you need to do to your car to dial in the fuel mixture David. David the first thing we need to know is if you have solid or biased needles, and what number/letter they are, the numbered needles, like #5, #6 are solid needles, it doesn't really matter for street car, biased or solid, but we need to know what needle to have to make changes and have those needles on hand.
toysrrus said:Howdy Gents,
Hey; Can anyone join in on the fun next wk. Tues?
Regards, Russ
JPSmit said:Hap, I'm pretty sure I'm running a #5 with a single HS4 - should I be looking at a #3 or #4 - how can I tell? I think I fouled a plug once or twice last summer.
Hap Waldrop said:David, your needle number reflects the later biased needles, which are spring mounted, we can graph that needle on a chart and see what coms up leaner, and get those needles, we can also use a special bushing and convert them to solid needles as well, it baised needles don't give us the choices we want, I did that exact thing to Tom's race carbs yesterday right before you stopped by. For starters we just give them a good look over, and see where we're at.
David, being the great photo and flim-maker you are, you want to film Tom's dyno session, we could then put it on youtube for the masses.
