Don't wish to teach my grandmother to suck eggs but it is important to realise that bolts and set screws, although similar to look at, were designed with different purposes in mind. Bolts were designed to be used to clamp two or more components (usually with unthreaded holes) and usually with a nut on the end to do the clamping, although not in some cases as they are often used for attaching pulleys where advantage of the unthreaded end is used to give a "dowling" effect. Set screws are used on (usually blind) fully threaded holes and as the thread goes right to the underside of the head the clamping effect is achieved by torquing them up. So try not to use a set screw to clamp unthreaded holes, you might get some slop damaging the hole over time. Well that was the theory anyway.
Grub screws (well our grub screws anyway) do not have heads. They are threaded along their length and can be screwed deep into a threaded hole. They have recesses machined in the end so they can be tightened using an Allen key or small flat head screw driver. You normally find them on instruments.
AJ
ps I disagree with TOC. All that will be left after going thru his list will be the hole that the pistons fit into!
AJ
