Can I assume that you checked the harmonic balancer? The woodruff key can be worn causing some play. Also check to see the rubber seal on it hasn’t delaminated. Loose crank nut?
Hi Guest!
In the 70’s I used to overhaul big Healey engines and on tear downs on a couple of engines I found a timing chain tensioner that the piston part of it was almost out of its socket. The chain was very stretched and loose. The engine made a noise, it also burned oil too so an overhaul was in order. And on another engine the generator was making a ticking noise. Disconnect the fan belt to eliminate this possible cause too.Hi Patrick,
No, thank you for bringing up that possibility. As mentioned, the tapping is regualr and seems singular and has not been deminished when disconnecting the spark plug wires, one by one. Although pulling the engine and doing a full rebuild would probably eliminate the problem. However, this would be an extended expense I don't feel would be needed on an engine performing so well. Although the tapping appears low in the engine, we all are aware that sounds emitted from the engine are not always located from where they appear and, as Patrick's suggestion indicates, could be caused homed somewhere different. This is a regular tapping, not to different from a valve tapping but the sound appears to be coming from lower on the engine and not the valve train. So, what else could this be causing this tapping?
We appreciate all the comments as this issue has stopped the use of a recently completed Healey by its owner for his fear of having a catastrophic engine development.
Ray(64BJ8P1)
One last thought from me. I had a “ticking” sound that didn’t change with engine revs. I adjusted valves, etc. good compression. It turned out to be broken rings tgatvended up on a piston top. Can you get access to a borescope to look at the piston tops before you remove the head? I’ve had two different engines of my own that #6 piston went bad plus I overhauled a few that also had bad #6 cylinders.Hi Bill,
First, thank you for your comprehensive response. I will be at our "Positive Earth Drivers Club" meeting with my friend tonight and we are scheduled to take his car to another club member who builds LBC Racing engines next Tuesday. We have a workshop manual and have tested compression with good results. There is no miss in the engine and the engine seems to be performing quite well with the exception of the low end ticking. Although I would do all the tests prior to deciding on a full rebuild (if for no other reason but to save money), I must admit I am not a proponent of a full rebuild as so many taking this corrective action seem to report disappointment and additional problems after.
I respect your suggestion of pulling a local expert into the discussion, if for no other reason but to validate any conclusion and action plan. In this situation, and since it is not my car, any conclusion I would come to should be validated by another, and that other person should have great credibility (expertise) in this area. Whether my friend does some or all the work required or farms it out to our expert is a decision he will need to make. However, I must say that our expert is someone I would go to if I had a major issue I could not rectify.
I really respect the suggestions of this group and I can truly state that this respect was earned by the many suggestions I have followed to correct my issues and keep my unrebuilt engine performing quite well.
Thank you to all and I will keep you informed on what we find and the corrective actions taken.
All the best to all,
Ray(64BJ8P1)
Has anyone mentioned or thought about timing chain issues ?
