Heavy fuel odor in car
Randy Harris
66 BJ8. Drove top up today, a very rare occurrence. I was almost knocked out by the intense gas smell in the car. I immediately suspected carb overflow. Checked and no odor or fuel leaks from the engine. Scooted under the car expecting to see a drip or a puddle or something - nothing! I wasn't in a place that I could easily check the fuel pump for a leak but I would have expected to find some gas on the ground if it was leaking - nope. Looked in the boot thinking maybe a leak from the fuel filler area - again, nothing. But it does smell of fuel.
I'm open to ideas. What should I look for?
Thanks
Randy
Keoke
Hi Randy, Remo9ve all the carpets from the boot over the fuel tank and and check around the fuel sender unit.Similarly, remove the cover over the fuel filler pipe and make sure all the joints are tight. If the tank was full and the car parked for a significant time it may have overflowed into the drain channel around the boot lid a bit and penetrated under one of the small rubber bumpers or a loose rivet located along the bottom of the boot lid.---Fwiw--Keoke
Ed_K
Randy,
Check where Keoke said. If you cannot find any damp spots around the fuel sender or filler pipe connections;
Look carefully at the fuel line connection where it attaches to the front of the tank for dampness. You also better take a look behind the rear passenger side wheel for signs of pump or fuel line leakage. Other than these areas, your tank has probably rusted through somewhere and if you cannot find any damp spots on the sides of the tank, you may have to take it out and check it for rust through. My Healey used to have that strong gas smell in the boot and I never saw any wet spots. I pulled out the tank to clean and paint it. When I cleaned off the rust, I discovered that in one place, all that was holding in the gasoline was rust. When I cleaned it, it looked like swiss cheese in one area. I cleaned the entire tank and treated it with Jasco rust neutralizer. Then I covered the holes with masking tape and wrapped the entire tank on the bottom, ends, and sides with fiberglass. Once that cured, I used the kit that Moss sells to clean, etch, and then coat the inside of the gas tank. No more gasoline odors anywhere ! If you find rusty looking areas on the tank, that may be your " swiss cheese " area right under the paint and top layer of rust. Perhaps buying a new tank is less trouble than fixing the old one but it is more expensive. Your choice if you have the problem.
Ed
Randy Harris Heavy fuel odor in car Austin Healey 4
T supporting BE tonneau cover during heavy rains Spridgets 10
RAC68 Heavy Tapping low in the Engine Austin Healey 58
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
TulsaFred Heavy hex nuts Spridgets 8
RJS TR4/4A TR4A Heavy Clutch Pedal Triumph 2
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
athenssprite heavy smoke on start up - burning oil Spridgets 13
UmmYeahOk Shipping heavy bulk items [triumph related] Triumph 17
QuickSilver Right Snap Under Heavy Braking MG 9
Jer TR2/3/3A How long/heavy is a TR3A ? Triumph 6
C TR6 TR6 Heavy Duty Headligh Harness Triumph 9
B HEAVY WEATHER ALERT!! Tyler,Texas Regionals Triumph 2
kyreb1862 Heavy Duty Headlight Harness MG 2
RickB MGC Recommendations for heavy rust removal [MGC] MG 36
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
B Heavy Clutch Pedal Triumph 6
SCguy Installing a VB heavy duty light harness?--Up-date? Triumph 8
Nunyas heavy stumble at low RPMs - Catalytic Converter? MG 5
John_Mc Heavy duty manifold gasket Triumph 6
R Heavy Clutch Austin Healey 8
F Midget with heavy steering and no recoil. MG 7
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
