Has anyone used a lock nut to help secure the heater tap? If so, what size?
It would be great to know the size and thread before I start looking for one.
Cheers
I am referring to the thread on the tap. There should be just enough threads for a slim lock nut.
I do use teflon tape but there is just a very slow seep of coolant as the tap is slightly loose.
It looks like a fine tread maybe 5/8 in.
thanks
I gave up on the jam nut and just cleaned and reinserted the tap, along with clear silicon adhesive/sealant.
After seating it as far as previously set, I very gingerly turned another 360 degrees. It is holding tight.
The tape does have tapered pipe threads. They were slightly deformed as far as it was tightened previously.
I believe that the softer threads on the tape deform to fit the steel threads of the head.
