Hi Bill. The motor is probably frozen. I took a motor from a junked MG Midget and with some effort got the TR6 fan on the shaft - it worked OK. Remove the glovebox and pull the heater unit out that side. It'll get hung up on a few things, but with the right swearwords, it does come out.
Before you go through all the trouble of pulling the fan, you might consider just pulling the heat full on.
Even without the fan the heater core puts out lots of heat; enough to keep you comfy.
How much winter driving do you expect to do?
