TR2/3/3A Heater Delete
CJD
Yesterday I was driving the TR2 to go see Knucklebuster’s new project. After a few miles I pulled away from a light and thought to myself...”Self, I recognize that smell”...hmmmm...and as anti-freeze finally came to my mind I felt hot dripping on my feet. Heater core blew out. Bummer. First time she’s broken down since finishing the restoration 3 years ago. But she made it home on her own...albeit giving me a wet foot.
So today I spent an hour doing a heater delete. I’ll try to find a good core (easier said than done), but in the mean time I’ll be heater free. I mean really, I have used it more trying to cool the engine as an auxiliary radiator in stop and go traffic than I have used it to actually warm the car!?!
Does anyone know if any vendor is finally repoing the core, or is used still the only option?
CJD
CJD
Well. I see from the large number of responses that used is still “the” option! That’s OK, like I said, I never use it anyway. I’ll live like Dan and pretend I live in Hawaii for a while...just no ocean...or mountains...or cool volcanoes....and ice storms...and tornados...and
...you know, I reckon I have a lot of pretending to do
2long
Thanks John! Heater delete does have its advantages in terms of simplicity and circulation. And it’s been a while since the last ice storm over here!
Dan
DavidApp
Hello John
I replaced my leaky core with a new core from Clayton but I got it direct from the UK.
https://www.holden.co.uk/p/heater_element_without_motor_plate Check out their site.
I had to shorten the motor shaft and space the heater down about 2" but even sticking your head under the dash you can not tell it is not the original one.
David
I have a lot more photos of the mod to the heater. It works well.
GilsTR
I installed a Spitfire heater in our car.
Bolts right up.... no mods necessary.
Got the tip from Bob Shaller from AZ in his booklet More BS on Triumphs.
Kept the original.... could easily be put back if some day #1 son so chooses.
Gil. NoCal
mrv8q
Would closing the heater water valve in the engine bay stop the leaking?
LarryK
Closing the heater only stops the flow not the back pressure from the other hose.
CJD
CJD
Excellent. Good to see there are options. I’ll check them out and make a decision by ice storm season. Thanks guys! I’ll update when I decide.
CJD
CJD
Thanks JP, but I’ve grown tired of working with the old used cores. Honestly, I think I have been through 5 of them, and the current blowout was the best of the 5. You will likely need both of yours to get one good one by the time you clean and test them. I really appreciate the offer, though!
DavidApp
What I gathered during my heater journey was some of these cores were tinned steel. Also that the would deteriorate if stored for years.
The heater I had installed seemed fine for a short time but when I added the antifreeze mix and got the engine up to temperature I developed a pin hole leak.
The thought of all that hot water right by my knees prompted me to go the new core route.
David
D Heater Delete Spridgets 24
bugedd Heater Delete Spridgets 7
QuickSilver Heater Delete MG 11
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R TR6 Heater control bezels TR6 Triumph 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
Got_All_4 TR6 Heater upgrade Triumph 6
Michael Oritt Heater motor or switch problem Austin Healey 1
