Healy speedometer is running too fast
You haven't provided much data, but I've been working a lot on my speedometer(s) lately so I'll try to help. First, has this just started, or has your speedo always indicated high? Is it (reasonably, for a Healey) steady, or does it jump around? Do the odometer and trip meter seem to work correctly? Does it read accurately on the way up, and too high on the way down?
Assuming it's reasonably steady--Healey speedos are rarely rock solid at all speeds--and the odometer works you can probably calibrate the speedo with a formula (e.g. https://www.angelfire.com/fl/procrastination/rear.html ) or over a timed mile. Remove your speedo from your car and twist the chrome bezel to remove the glass. The needle stop can be pushed back into the speedo to allow the needle to swing freely. With the speedo in a normal vertical position note the position, then gently pull the needle indicator off--it's a press fit--and replace it at about a 5mph slower position. Push the needle stop in to get the needle on the correct side, reinstall in your car then test again.
If the speedo reads 10mph fast across its range this should get it close. Note that the speedo isn't likely to be spot on at all speeds, you probably want it most accurate between 30 and 70mph, below that you shouldn't get in trouble and above that it's just a matter of how much trouble :wink:
Hey Jersey,
Do you have the original rear and transmission in the car? If your car did not have an overdrive, that could cause he problem. That was the case with my speedo. I neeed to get my recalibrated since I replaced my transmission with a Toyota 5 speed.
Humdog
Since it is getting hard to find the original size tires, that may be an issue also. A smaller diameter tire will have the speedo reading higher that you're traveling. 10 MPH seems a bit much though, unless the tires are much smaller than the 26" diameter of the originals.
Thanks for the input guys...tires are larger not smaller and the transmission is original... that leaves me thinking I will recalibrate and see what happens. The reading is fairly consistent but I need to apply the scientific method to pin it down.
Thanks
Jersey
Bob - Thanks for the insight and the link...it has been a consistently reading over so I think you are on to something...I need to do some more diligent fact finding and the link you sent me has plenty to work with.
Thanks
Jersey
