I have a couple of questions for all you Healey enthusiasts out there. I have a 62 3000 BT7 Centershift and it was restored previously to my owning it. Runs well and shifts fine, however, when I start the car, and I'm idling/warming up,in the garage, I then try to put in gear from neutral and she wants to grind. I have tried all gears but cannot engage. (Obviously with clutch pedal pressed). If I shut car down, then engage into any gear (easily done) I can press clutch, start and It will run fine, all day. Only the initial start up. Any ideas? Is this normal? 2nd question. First gear sounds different than all others, almost like a growl, or whiring sound. Is this normal on these gearboxes? Again, no problem shifting and All other gears sound great. I usually start out in second gear. Thanks , Pete
