Might be an existing thread on this, but wasn't able to find one. There's existing info on the web & a few of the euro Healey parts sources sell a larger 1 3/4" dia. Accumulator Piston & stiffer springs to upgrade the Overdrive to a fast street or Works level of operation. It sounds like the Accumulator Housing isn't used when you step up to the 1 3/4" dia piston. The only change I've read so far is the overdrive shifts quicker & maybe can handle more torque for the modified engines. My thought is the Accumulator Housing gives a replaceable wear surface for the Steel Accumulator pistons.
I'm in the process of rebuilding an overdrive, that needs a new Accumulator Housing & piston & wanted to get feedback on the plus/minus's of the larger piston & stiffer spring's. My Healey won't be driven to the limit
Link on Overdrive problems & Upgrading info
https://www.ntahc.org/techtips/OVERDRIVE1.html
