"Healey 5-Speed"/Pete Delaney Contact
WHT
Hi Bob,
It was sent to me without adequate packing and the transmission rolled around in the box during shipping. The input shaft punctured completely through the box 8 times (no idea what it hit or the damage that was caused). When it arrived, the input shaft would not turn. I was told by Driven Man to take both hands and it would turn with sufficient hand force. Later, I found it would not shift into first gear.
After dealing with Driven man over problems like missing kit parts, the wrong kit parts and snarky comments from Their Technical and Return Department, I decided to take it to a well known local Tremec shop for inspection and repair if needed; at my expense.
This decision was partly made because I did not have a secure box to send it back. When I voiced my concerned that (i) the original shipping box was not in good enough condition to return the transmission and (ii) I wasn't sure how to build a skid for it, the return manager said: "What do you want me to do? Drive over to your house and pick it up for you?". I was also told once you buy a transmission, it becomes your transmission and it will not be replaced. So, I would have to live with any additional damage caused by not shipping it back in a secure box and being blamed for causing more damage. All of the responsibility was put on me.
The local Tremec shop said they thought the damage was likely caused by the synchronizer keys being installed incorrectly and then the gears were pressed into place, breaking the rings and spacers. Additionally, they said the input shaft/ bearing (and other shafts) did not have the correct preload. The Tremec shop said the transmission, modified by Driven Man for the Austin-Healey, showed very poor assembly in their opinion.
After seeing the condition of the transmission, I could not imagine sending it back and having the same tech work on it again.
Regards, Bill
Guido36
Bill’s horrible experience is a reminder only ro buy retail parts with a credit card with strong customer backup and guarantees. I bought my McCleod 5 speed for my Healey through a highly reputable distributor, on a credit card. Let the credit card company duke it out with the supplier.
Rob Glasgow
I would hope Driven Man will respond to this forum with how they will make this right. When you’re a firm suppling parts to a very passionate and small community of customers, to not do so would seem like a poor business decision.
Hi Bill,
It sounds like the tech broke the box when he pressed the gears on, yet assembled it anyway? Unbelievable.
I thought the name 'Driven Man' sounded familiar: I'd checked them out for a possible Tremec swap for the Getrag in my Mustang. There are reported issues with the Getrag, at least older in versions, and I'd had a Tremec in my '08 Mustang and was very happy with it. But, so far I've had no issues with the Getrag and I'd rather spend my money elsewhere (the Mustang doesn't get driven much these days anyway).
One thing about driving older cars, like Healeys, is that you tend to learn how to 'baby' a gearbox (they're not for 'speedshifters'). I've always remembered Mario Andretti's comment that he 'treats the shift knob like an eggshell' and Norman Nock's advice to 'always pass through neutral' (which I assume to mean no straight shots from second to third).
PAUL161
My T9 5speed can be shifted pretty quick and has a very short throw, but I soft shift it and it shifts beautifully without any strain on anything. The original transmission is in perfect shape and has never been abused, just wanted an extra gear. (y)
WHT
Hi Paul,
I installed a Type 9 (T9) 5-speed transmission in our 1951 MG TD five years ago and it has worked perfectly. It was purchased from Hi-Gear Engineering in the UK and the kit was wonderful to install. Like you, we wanted a 5th gear for cruising.
The Hi-Gear kit was extremely well engineered and included every part required including the transmission fluid (which gave the EPA a hissy-fit and required me to file forms for importing hazardous materials). :(
(i) All parts were carefully checked off in the kit and all of the parts were there, (ii) all of the parts fit exactly as designed and intended, (iii) Hi-Gear included a very detailed and technically correct set of instructions and (iv) the transmission and other kit parts were carefully packed and protected for shipping. It was a night and day different experience than the Driven Man kit!
The owner of Hi-Gear and his wife are amazing people to deal with and they do a terrific job engineering, modifying and shipping transmission kits.
Regards, Bill
Michael Oritt
"Of course a Toyota gearbox is better than the original but then you aren’t driving an Austin Healey"
More accurately, you'll be driving an Austin-Healey with a Toyota transmission versus perhaps simply owning (but not driving) one with an Austin-Healey transmission.
HealeyBN7 Reaching Pete Delaney - Healey 5 Speed Austin Healey 26
60TR3A "Car Crazy" on Speed Channel: "Healey Week" Austin Healey 6
B Healey 5-Speed Conversion Austin Healey 27
Robert560 Speaking of dowel bolts - Healey 5 Speed guys.... Austin Healey 5
CharlieCarpenter Smitty's Healey 5-Speed info??? Austin Healey 13
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyRick Perfect Healey Floor Jack Austin Healey 14
T Netflix Christmas Film with a Healey Austin Healey 4
W For Sale 1954 Nash-Healey Le Mans Coupe Other British Classifieds 2
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
