Hello all from UK. For sometime I have noticed a very little amount of water leaking out near the two middle plugs. Also some emulsion on the rocker box, but no noticeable oil in the water or vice versa. Having had the fan belt come off and now fitted a new one and checked the Dynamo ( see my previous post about Dynamo with a mind of its own ). I decided to check the compressions although the car is running very well and the engine is smooth, What I found was the following whilst HOT -- from the front cylinder back -- 160 - 120 - 117 - 155 lbs. So now I am going to have the cylinder head off. Totally dismantle and grind in the valves. Bought a new gasket set from AH spares. What I would like to know is there anything else I should do whilst the head is off? We are going measure the head on a flat surface and skim if required. I believe the original manual suggests that the head is torqued to 60 lbs ? Is this correct as I had heard that 100 lbs is correct, but I do not want to risk the studs snapping. Are there any clever tips to stop this happening again, as I believe this is a typical Healey 100 problem. Thanks John
. I will post another reply when we have fitted it -- hopefully next weekend, if it arrives.
