Healey 100 dip stick
Walker sim
Hi All,
My BN1 dip stick's, for wont of a better adjective, 'hole stopper', slides up & down the stick. The stick hits the bottom of the sump when I take a reading. Is this normal or should the stopper be fixed on the stick for a correct reading?
Cheers,
Wal
Michael Oritt
Wai--
If by "hole stopper" you are referring to the outer tube into which the dipstick is inserted, it--the outer tube--should not slide up and down, though I don't offhand know how it is fixed to the block. And without removing my pan one would have no way of knowing how far off the floor of the sump the tip of the dipstick rides when fully inserted, though I would bet it should be pretty close to bottomed-out. In any case the important thing is that the dipstick marks conform to the proper oil levels, of course after the filter is full. From memory this amounts to about 6.5 quarts US.
Michael Oritt
Well, as Gilda Radner's character Emily Litella used to say: "Nevermind"....
W
Walker sim
Hi Michael,
My block does not have an outer tube, just a hole in the block. Steve has caught the drift, is the limit piece supposed to be fixed, if so, where?
Thanks, Wal
red57
It has been over 45 years since I had a 100 but most all motors I've ever had have a tube (usually pressed in) that the stick goes into - see #91 in the Moss catalog. The fact that you go directly into the block says that the tube is missing. You need to get the tube and press in and then, if you don't have someone near by to compare dip sticks with, give it an oil change and fill with the correct amount of oil and see if the full mark is where you are - if it doesn't read full then you may need to adjust the tube insertion depth. BTW, look at the stick on the Moss drawing (#90) and you can see the washer on the stick just above the dust boot/rubber (#92). That washer is supposed to be brazed in place and is the stop for insertion depth, stopping against the top of the tube - never heard of one that hits the bottom of the pan so that makes me think you may be reading more oil on the stick than you actually have.
I urge getting this sorted prior to driving as you are playing with fire if you don't know how much oil is in the motor.
Dave
Michael Oritt
SWal--
Go to: https://mossmotors.com/austin-healey-100-100-6-3000/engine-performance/external-engine-100-4
Your engine should have a tube (p/n 91) into which the dipstick (p/n 90) goes. The rubber dust cap (p/n 92) does wind up on or just above the top of the tube but as I think about it there is a solid feeling when I fully insert the dipstick into the tube, telling me that the bottom of the dipstick is landing against the sump, and dust cap merely shrouds the tube against...dust.
I recommend that you get a tube--Hope this helps.
Michael Oritt
I just checked my car and there is no washer brazed to the dipstick nor has there ever been one since I have owned the car. That is not to say that there should not be such a washer but there is no "stop" on the dipstick as mentioned by Red and perhaps the repeated in-out of the stick by previous owners broke the braze resulting in the washer's loss, etc. In any case--on my car at least--the bottom of the dipstick is definitely landing against the inside of the sump which sets the depth of the add/fill marks on the stick which have worked for me over the years.
I am attaching a close-up pic of my stick showing two small holes I drilled at the add/full lines. When oil is fairly new and has not yet picked up a lot of contaminants, etc. it is sometimes hard to accurately read the oil level on a stick. However the presence of oil provides a film that remains in the holes, whether or not the oil is clean, and makes for easy reading.
red57
Well, apparently the 100 sticks don't have a washer, as I said it's been over 45 years since I had one. I looked at the Moss drawing to confirm it's the same configuration and it clearly shows a washer on the stick, however the washer may serve a different purpose.
On the 6 cylinder motors the stick is flexible enough and going in at an angle, so that it seems like it would be a bit variable as to how far down the stick is inserted whereas the washer method on the 6 cylinder is a positive stop every time?
Anyway, sorry for any misunderstanding.
Dave
Michael Oritt
Red--
I agree that the Moss catalogue drawing shows a washer which may be a stop--there simply is not one on my car and there appear to be multiple braze marks on the stick where the two half-oval segments are attached together above the immersion point, I assume to stiffen the stick and form a finger loop/finish off its appearance.
Steve--
My pan is flat and I would think that a dent big enough to make a significant difference in oil level would probably cause different problems such as a hole!
John Turney
I used to work with leaking underground storage tanks. The holes in the tanks were usually right below the port where they would insert the dipstick to measure tank level.
steveg
FWIW - For grins, I ran this one past Mike Salter, who has decades of experience esp. with 100s. His reply:
"Hi Steve, yes I'm pretty sure it does [rest on the surface of the oil pan]. There is no stop on the dip stick and quite often you will notice a polished area in the sump where it rests.
I also recall inserting the dipstick into a block before installing the sump and went all the way down until stopped by the loop."
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
R Healey 100 Dipstick Stuck Austin Healey 12
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
Guido36 Webers on a Healey 100 Austin Healey 6
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C What to do with my late father's Healey 100 Austin Healey 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
B Overcooling Healey 100 Austin Healey 13
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
dougie Austin-Healey 100 Documentary Austin Healey 3
H 100-6 Austin-Healey Austin Healey 7
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
Lin Spruce Green Healey 100 Austin Healey 17
G For Sale Healey 100 windscreens for sale Austin Healey Classifieds 2
N Healey 100/4 from the Bahamas Austin Healey 8
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
C For Sale Healey 100 for sale Austin Healey Classifieds 3
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
W Healey 100 Overdrive stopped working Austin Healey 15
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
D Healey 100 issues Austin Healey 15
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
H Healey 100 Painting Austin Healey 5
W Austin Healey 100-6 Sell or Restore? Austin Healey 5
L For Sale Austin Healey 100 literature for sale Austin Healey Classifieds 1
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
