rjc157
Just purchased halogen headlights and for some reason the left side is bright and the right side is dull I switched the bulbs thinking it might be bad but the same thing do I need relays on them to make them work or just go back to non halogen alt seems to be working reads 14+ and with all lights on reads 13+ have to add that at idle the rpm's do drop but lights stay the same brightness could it be the alt,my next step is to check the wiring and see if there is any corrosion on the connectors and run new wiring
