Headlights Stopped Working
Flatlander
I have been putting this day off for 10 years but now am forced to confront. When I purchased my car I knew the car had been rewired at some point in its life. The headlights have stopped working so I need to trace the problem. I can hear the relay clicking but no lights. After removing the dasboard it appears that the existing wiring was modified to accommodate the insertion of numerous relays. Starting off I had a number of questions:
1. Is there a wiring diagram for the S2 Vixen? Lacking that do the wire colors match the standard British car colors?
2. Being a novice to electrical issues any idea why so many relays? I can only think of the normal ones; horn, headlights.
3. As a side bar, does anyone have a photo of their dash inards? I was curious how the steering column is supported. On my car it is supported by a bracket on the rear of the dash and attached by a radiator clamp.
Thanks,
Gary
F
Flatlander
Ok have resolved most of the problems and am down to the final one. My tach has been flaky since I bought the car. I am replacing it with another electronic tach from a Spitfire 1500.
My question relates to the wiring on the existing tach. Any idea of the purpose for the wire loop on the back of the tach? On the 1500 there are two leads, one for (plus ground)power and the other to receive the signal from the coil to register the firing of the cylinder and the thus convert to an rpm value. (Do I have that correct?) On the existing tach there is only one wiring connection (plus ground)which looks like for the power. Does the loop on the back of the existing tach produce some sort of inductive pulse which the tach reads and converts into an rpm?
Thanks,
Gary
R Headlights - suddenly stopped working Austin Healey 31
W TR6 Headlights Triumph 5
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 19
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
S TR2/3/3A little caged nut headlights Triumph 2
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
P Porsche with 5 headlights Other Cars 5
Scotsman TR2/3/3A LED headlights Triumph 4
C TR2/3/3A How to wire headlights for TR3 Triumph 5
AUSMHLY LED headlights Austin Healey 36
rjc157 headlights Austin Healey 12
turbofrog Sprite Control Box - Headlights In-Op Spridgets 4
P Headlights and Turn Signal Light Grounding Spridgets 3
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
T TR2/3/3A TR3 headlights Triumph 12
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
D BN2 headlights Austin Healey 3
RickB Lucas Headlights - Just got this from VB Spridgets 8
N Headlights?? Spridgets 8
I Suggestions for bugeye headlights Spridgets 21
B Adjust headlights/ "true" them? MG 7
A TR2/3/3A TR-3A Headlights Main versess Dip Triumph 10
Nelson No more forgotten headlights Spridgets 2
PATR8 Wedge TR 8 headlights problem Triumph 11
AngliaGT New Elise Headlights Anyone? Lotus 2
N Adjusting headlights on a BJ8 Austin Healey 2
H Headlights left ON reminder MG 3
Nelson Aiming headlights Spridgets 1
Trevor Jessie Headlights Spridgets 34
M Headlights and fog driving lights Triumph 44
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
B HID Headlights? Spridgets 4
mountainman TR2/3/3A TR3 Headlights Install? Triumph 6
