Headlight relays!.....
Now that's a ground!
Got 4 of them in the car
This is the one in the boot
This is the one on the drivers fender
This is under the dash
Hmmm, can't find that one at the moment
I haven't used them for just headlights, but should work out fine.
My plan is to use self-resetting circuit breakers, after I found some for $3.50 each at a local electronics store. I'll hide them and the relays, to minimize visible changes.
Question for Randal? What does the purple wire represent? I was expecting three wires, low beam, high beam and ground? Did you create a new harness from dimmer switch to each headlight? IF purple wire is the power to drive lights, did you connect this to the A1fused connection to maintain amp meter functionality?
