Help!
After a long drive last night, the headlamps worked perfectly and shut off just fine.
This morning, the headlights would neither rise nor shine when the swtich was pushed down.
When switched to parking lights only, all the front and rear and side lights worked fine. When the switch is pushed all the way down, only the interior instruments lights worked. The lamps did not appear to shine nor did the headlights try and rise.
When the light switch is "on," there's no high beam indicator as there would be in the lights were working but not elevating.
As an aside, the high beam indicator does flash when you pull the stalk towards you. I could not tell if the lights acutally illuminated.
Can anyone help me? I need to get home tonight!
Jeff
Jeff
