TR6 Headers? TR6
Bret Cutler
I am looking here.
Header page Rimmer Bros
I am looking at the two header styles they sell in stainless. One is a pair of 3 into 1's I like it because it empties right into dual exhaus without having a y pipe. It is also cheaper. Has anyone seen these pipes? Quality good? Any othe stainless headers i should be looking at in the $250 range. Thanks alot,
Bret
B
Bret Cutler
please reply to the other one. I forgot to make it so i had email notification... That should be the default anyone else agree?
aeronca65t
No idea how good Rimmer is (or what the shipping would be to NA)....but the Pathfinder (non-stainless) headers for the 1500 Triumph (in my Midget) were terrible. Welds were OK and material looked alright but fit was dreadful.
piman
Hello Bret,
I cannot comment on the Rimmers exhaust manifold,
(Britspeak for Headers), but there is a strong opinion that the best set up for the Triumph six is a six into three into one, fine for my 2.5 saloon with its single exhaust pipe. TR6's could be a problem. Chris Witor (a well known 2000 saloon specialist www.bartlett-printing.co.uk/chriswitor.html) sells such a manifold, made in mild steel but that comes out at over three hundred pounds sterling.
The performance gains of such a system are supposed to be quite considerable. I don't know what 'Kas' Kastner used when he raced TR's in the 60's but he was able to get more power than anyone out of the 2.5 TR engine. he also published a tuning manual if you can find one second hand.
Alec
MDCanaday
Check cambridgemotorsports on line for some fine speed parts and a wide selection of headers, bear in mind that the prices are lbs not dollars, and freight is another factor.
To get cheap HP on a tr6 , the first thing to do is mill the head 125 thou. shorter pushrods are needed to keep rocker geo. good. This gives 9.1 to 9.25 comp ratio. do this first then get the best headers you can afford , it will run great for very little $$
Mark
B
Bret Cutler
i will be running a blower so compression is my enemy. I just want a header because the air at that point isn't being forced out any faster then without the blower. thanks i will check out that site.
MDCanaday
What ever header you get the first thing to do is(if it is a single flange,one piece style) make sure the flange is not warpped. Most are,some badly. this must be fixed before attempting installation. Also check port match, a little work with the dremell pays big here.
I hear the blower works great on the 6 due to the lower comp. How is your low end?? You might want to nitrite the crank and balance it for durability, as you will be making a bunch of power.Also the stock rods need love(shot peening, and fresh bolts)
Have fun!!
Mark
B
Bret Cutler
I wasn't aware that you could have things nitrided?? Where is this done and how much stronger will it be? I am going to post in another post about building a short block and what people have used in there high horspower searches. Please see that post to write about that. Lets keep this one headers. I still am looking for someone that knows about the Rimmer Quality. Thanks alot,
Bret
T TR6 TR6 [?] headers - actually any good? Triumph 7
W TR6 TR6 aftermarket headers Triumph 26
A TR6 Headers --VS.--Stock header??? tr6 Triumph 32
kodanja TR6 71' TR6 HEADERS Triumph 6
3 Exhaust Manifold/Headers BN2 Austin Healey 16
steveg Headers to buy - DW or AHspares? Austin Healey 5
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
R General Tech Kirk Racing headers opinion Triumph 3
Bremer TR2/3/3A 4-2-1 headers [or Tri-Y] Triumph 5
R TR4/4A Were the exhaust headers painted on the TR4's Triumph 6
D Headers for BN4 Austin Healey 2
Morris Good Deal on Cheap Headers Spridgets 6
bighealeysource Derrington style exhaust headers on 100-4's Austin Healey 4
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
racer_x Wedge TR8 Group buy- Kirk headers Triumph 5
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
JPSmit Patriot Headers Spridgets 1
Aggudabbu LCB/ Headers clearance issues? Spridgets 4
LuckyLuke Who makes exhaust headers for AH 3000 BN7 Austin Healey 7
hymodyne GT6 GT6 headers Triumph 14
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
NardisCNC Who makes the best headers?? Spridgets 9
drooartz How the *bleep* do you fit the headers? Spridgets 11
RSMTR8 Wedge TR8 Headers Triumph 13
GBRandy Wedge Headers on a FI TR8 Anyone do it? Triumph 9
5 Headers for BN4/early 3000 Austin Healey 10
drooartz Jet-Hot headers came today! Spridgets 5
boeingpilot GT6 GT6 Headers Triumph 3
tony barnhill Patriot 1500 Midget Headers Spridgets 3
A new headers Austin Healey 3
chrisc Wedge TR8 Headers/Exhaust Triumph 46
G I called Jet Hot about my peeling SS headers... Triumph 20
amcboy Headers, and what I intend to do about it.... Triumph 4
G Jet Hot coating peeling off my headers........... Triumph 9
T tvr 2500 headers TVR 0
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
73MidgetLigon Wrapping your headers is it worth it? Spridgets 11
S headers ? Triumph 20
G Catalyst location for a car with headers Spridgets 17
DNK E bay headers Triumph 0
G Removing my engine/tranny with Headers.... Triumph 4
T ok, lets talk about headers Triumph 9
T TriumphTune Exhaust Headers? Triumph 23
Brosky Pacesetter Headers Yes or No? Triumph 13
T TR4/4A tr4 headers-sizing Triumph 1
C Don... Those Headers? Triumph 11
M 'Kirk Racing Headers' need feedback Triumph 2
beez ceramic coating on headers Triumph 14
J has anyone used pacesetter headers and monza exhau Triumph 2
