TR2/3/3A Headers and Starter on TR3
martx-5
I see from all the vendors, that some headers will not fit TR2's and TR3's up TS50,000 because the starter is different. Where exactly is the interference problem??
Will one of those gear reduction retrofits solve this issue??
Also, what would it take to put the original LATER starter into the earlier engine??
[ QUOTE ]
...Also, what would it take to put the original LATER starter into the earlier engine??
[/ QUOTE ]
The problem is 2-fold. First the nose of the later starter is longer requiring a bulge that was built in to the later bell-housing. Some punch holes in their early bell housing to allow for the longer starter. Second, the later starter should ideally have the later bolt-on flywheel. Mating the later starter to the early press-on flywheel might or might not work depending who you ask.
Hi,
Yes, a high-torque/gear reduction starter might be the ticket, giving better starting ooomph along with much smaller size and ease of installation. I'm not sure about using one with the earlier, press-on ring gear Geo refers to, though. Better investigate that. Try www.britishstarters.com
Another concern is if your car has a high port or low port head. Some early TR2/3 heads have all the ports lined up (called "low port"), while the later have an alternating high/low arrangement of intake and exahust ports (called "high port"). Headers for the later heads are much easier to come by. Headers for low port heads might need to be custom made.
Other considerations...
Headers will add to underhood temperatures, since they pass heat more easily. They will also add some noise.
Due to the greater radiant heat from headers, heat shielding is highly recommended for any nearby items that might be effected: starter, carbs, generator, fuel lines, brake lines.
A possible solution and alternative to shielding is to wrap the headers (a newly-popular, old idea borrowed from 1950s hot rodders and drag racers). In order to be fully wrapped (100% coverage), a header should be stainless steel that will be more expensive.
A mild steel header can be wrapped with only about 70-80% coverage, or it will corrode much more rapidly. A better alternative with mild steel might be to have the header ceramic coated. This can even be done to rejuvenate a rather ugly, but sound, used set of headers. Check out www.jetcoat.com
Wrapping or ceramic coating will both effectively void any warranty on a new set of headers.
Headers are a good, bolt on performance upgrade, done right. The late, TR4A dual pipe exhaust manifold was actually pretty good... but replacing earlier manifolds with headers will give more noticible improvments.
Your carbs might need rejetting or tweaking after headers are installed, since gas flow will increase and the engine will breathe more efficiently.
Have fun!
Cheers!
Alan
Hi,
The new gear reduction starters are available for the 2/3 pressed on ring gear. The early flywheel is definitely worth keeping since it is about 8 or 9 pounds lighter than the later ones. I had one machined years ago just for that reason to accept the bolt on ring gear. And I can vouch for the heat reduction obtained from getting your headers ceramic coated. Good luck.
