Although I know I need to do a compression test, it will be a week
before I can get around to it, but I thought I'd raise the issue.
A couple of weeks ago, while on the tollway, I blew a radiator
hose. I pulled to the side of the road before it overheated and
had it towed to a shop I know, where they replaced the hose.
They said they thought I might have a blown head gasket because it
took a long time for the bubbles to stop after they refilled it.
This despite telling them the car has to be bled the correct way.
Anyhow, I have been paranoid about it overheating and have been
checking the coolant religously. I have had to had a little bit
every time, but have attributed it to improper bleeding. THe
reservoir always had air in it, but the crossover pipe was always
close to full.
Today, after the car has been sitting for a couple of days, I went
to check the coolant. When I opened the cap, fluid squirted out
under pressure. It hadn't done this before.
The car is not overheating, and there is no sign of coolant in the
oil or at the breather.
The overflow is clear, though I didn't hear any bubbling when I blew in it.
Any ideas?
close to full.
Any ideas?
