I have done a basic rebuild of my HD8 carbs on my BJ8. I loosened both of the throttle shaft connections when I removed the carbs. Now I am ready to tighten each carb onto the throttle shaft and fire it up. I noticed there is a bit of play before the throttle shaft actually engages to the carb shaft (maybe 5 to 10 degree rotation before they engage).
Do I leave that" slop" when I retighten?
It would seem to create a slight delay before the throttle engages the carb shafts unless I take out the slop during initial setup. I realize I may need to adjust each separately when I set the mixture/idle synch when it is idling. My intuition is to take out the slop at set up. Been wrong before though.
