HD8 damper with Brass or plastic cap?
AUSMHLY
My 64 BJ8 HD8 carburetors dampers have a plastic cap. My friends 66 BJ8 HD8 have brass caps. Why do the same carburetors have different caps? Which is correct?
Stock photos from Moss.
gonzo
i understood HS6 (BJ-7s) and HD 8 (BJ-8s) carbs require plastic-capped dampers. On the brass ones installed on your friend's HD8 carbs, do the plungers offer any resistance? Too much or too little resistance will impact performance as described in your
earlier post. GONZO
red57
The stem of the damper is just a press fit into the cap - and will fit either cap.
Obviously they are different damper stems for HD6 vs HD8 because the different diameter means a different length damper stem but you can swap the caps.
My HD8s had plastic caps and I replaced them with brass caps because I think they look better. BJ8 stock HD8 should have plastic caps.
Dave
The other thing to look for is venting - they have to vent and some SUs have internal venting in the dashpot with no vent hole in the cap but others have no internal venting in the dashpot and require a vent hole in the cap.
Keoke
View attachment 58305View attachment 58306
II have personally never seen it happen but have seen and read of cases that happened , so I use the brass caps because they do not allow the shaft to penetrate the cap.
John Turney
The PO of my HD8s apparently had a shaft come through the cap. He glued a dime to the top of each cap.
Years ago I had a shaft blow through the black plastic cap so I purchased the brass. I found no difference between them. However, I went back to the plastic as I've been trying to maintain the originality of my BJ8. I carry the brass ones with the spares I carry in case I blow another plastic one on the road. They are both vented.
gonzo
The PO of my HD8s apparently had a shaft come through the cap. He glued a dime to the cop of each cap.
Yeah, that's what the PO did to mine too, but with a copper coin of foreign denomination. I liked the personal touch applied here enough that I would consider reproducing it with some other exotic coin that fits.
Patrick67BJ8
The only time I’ve seen it happen was when there was a big hickup on a Carb. Carb backfire.
dougie
I had 2 of the 3 plastic top caps break while racing on my SU HD8's, so I switched to brass about 8 years ago with no issues.
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
