Rabbits 32
Hi All,
I have a carburettor problem that is driving me around the bend.
I sent my 1964 BJ8 HD8 carbies to the best carby restoration company in Australia as my car had high idle speeds when running which I couldnāt get down by adjustment. Reports from the repairer said that the brass bushes were severely worn and they totally rebuilt both carbies replacing just about everything in both.
I got them back and its now worse with the engine holding whatever revs I take it up to while going through the gears once it heats up to 165 degrees, strangely it is OK will the engine is cold. Eg if I rev to 3000 revs into 3rd then the engine revs stay at 3000 revs unless I push the clutch in and āblipā the accelerator. It holds even the slightest increase in revs and is near impossible to drive.
Even though the carbies still stick after disconnecting the linkages altogether, I pulled the linkages out and rebushed/ refurbished everything. Adding spring pressure to the return springs only makes it worse. Additional springs make it worse. I have sent the carbies back (twice) and the repairers found that it had a bent butterfly shaft and replaced shafts and bushes.
I got them back and fitted them and they are no better.
I fitted another set of carbies of a unfinished restoration that had been rebuilt by the same company and the car ran fine.
Wayne
Wayne
