I have finally gotten around to tuning and getting my 1967 BJ8 going again after a basic HD8 carb rebuild. After a little tuning and messing with idle and mixture, I discovered a slight gas leak at both fuel bowls at the bottom of the banjo fittings feeding the fuel bowls. It is essentially an identical problem on both carbs. I have tightened with care and actually replaced the large bolts with new parts from Moss. I installed new fiber washers - I did not soak them as some have suggested. iIam doing that on a couple of new washers I had in my stash. Will install those after things cool off.
This is a slight seep more than a leak, but needs to be shut off. It is interesting that it is the identical problem on both carbs. I have questions for those with more experience. Also the new shut-off valves seem to be working correctly.
1) I adjusted the float levers to the specified clearance. Could that affect the seal around the banjo washers?
2) Is there any sealant that can be used on the threads or on the fiber washers that can enhance the seal? I am wary of using a sealant of any type.
3) Can a different style crush washer be used, i.e. copper?
Note: I replaced both brass floats with that new style that supposedly will not fill up with gas. I set the shut off arms at 7/16th.
