Hi guys,
I thought I would pose this question(s) here as I would probably get more valued responses since you are most likely more familier with the HD6 carb.
I bought "Jerry's" old HD6 carbs to replace my HS6 pair on my stock engine TR6. The carbs actualy fit very well and look fabulous, I had to cut the nice chrom connecter fuel line as the distance between the carbs must be about 1/4" wider.
So far I have the car running albeit a bit lumpy.
The jets are all the way up flush with the bridge, floats are as they came. The needles are standard "CV" and pistons seam to move ok.
On the front carb I am getting the occasional blow back "explosion" and it has a constant stream of vapour oozing out the entrance.
I have noticed the plugs seam very dry on it's side compared to the other side. However when I move the diaphragm lever plenty of gas injects out the top of the jet.
Is this a sign of richness ?
The back carb seams ok.
The car doesn't run well with the filters off.
The plugs are very black, however sliding the needles down(weakening) makes the car run very rough and hard to start.
Sometimes when I hit the gas the revs don't go up as if the Constant Vacuum is off or pistons haven't moved.
The idle is at 1000rpm with throttle stops backed off fully. (i am fairly sure I have no vacuum leaks )
What does the slow running valve do (spring loaded screw on top of carb body), where shoud this be adjusted. What happens when I screw the valve down or up.?
Float heights, should I lower ?
When I raise the lifter pin on one carb, should I be adjusting the other carb?
Any help appreciated. I will be able to take the car for a short drive tomorrow, so far I have just been fiddling with the idle.
Many thanks..
Many thanks..
