HBT7L/18762 - Preservation Update
I just wanted to pos ta quick update. Here is the history if you are interested.
New Member 3000 MKII Project
Pics Before Preservation
I've been working on the car - very slowly. My kids schedule has allowed me a good 10-20 minutes/month to work on the car.
I started with an oil change. As recommended - I removed the valve cover and oil pan. There was a fair amount of sludge. With lots of cleaning - it looks much nicer now. I put it all back together and added oil and a new filter. I went ahead with the modern spin-on filter for now. I prefer safety to originality until I can run some better oil through the engine for a while (probably forever). I spun the engine over with no plugs in and no fuel. I was able to see plenty of oil around the cam and some oil pressure on the gauge. Good to go!
Next was spark. I replaced the points and condenser and got new plugs. Of interesting note - the car had no less than 4 different plug types in the car! I got a new cap and rotor - but one of the spike screws seemed stripped. I'm sticking with the old cap/rotor for now. I got sparks in all 6 cyls.
Time for fuel. I'm sure it's a shock - but the SU fuel pump did not work at all. I took it off the car, rebuilt/cleaned everything, set the gap, and put it back together. Tic, tic, tic. Woohoo!.
I put 5 gals of super unleaded in the car and managed to get fuel up to the carbs (new fuel filter right by the carbs). Once I connected the fuel line - I started dumping fuel under the car. It looked like it was coming from the overflow. I pulled the floats and cleaned them up. One needle definitely looked stuck. I put everything back together and no more fuel leaks.
This time it's for real. Check the fire extinguisher. Turn over the motor - no start. Choke - no start. Starting fluid - no start. Hmmm....
I double checked spark. No spark now. I double checked the points gap, wires, power to the coil, etc. Nothing.
So - it's time to debug the ignition system. I've been reading a lot - and finally broke down and ordered a shop manual.
I'll see how it goes and post an update in a few weeks (or months). I think once I get spark - we'll know whether it will run or not w/o carb rebuilds (truthfully - I'm trying to avoid this).
Grover
Plano TX
Grover
Plano TX
