John_Mc
My hazard lights don't flash and I'm trying to figure out why not. So using a voltmeter, I turned on the switch and checked the power to the hazard relay and I was able to get a reading of 12v so I checked the power into the flasher plug and I was able to get 12v. I checked the power OUT of the flasher plug and on one wire (LG/K) I was able to get 12v but on the other I got nothing. So I thought maybe my flasher was sticking. I took it out and banged it against the wall :hammer: and put it back in. No flashing lights. So I checked the above contacts again and now I was getting sporadic readings that seemed to settle at 2-3v. So I began to suspect the switch and I turned it off and on a couple of times. Now I get no voltage at any of the above spots. Again I'm suspecting the switch. However, switch or not, I would have thought that while I was getting the 12v readings, something would have lit up somewhere. Questions:
1. If it is the switch, how do I get it out to check it? (I've never removed the dash)
2. Is there anywhere I should check BEFORE the hazard switch?
3. Any other suggestions?
TIA
TIA
