When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
The nut holding the rear bumper to the car is in a very small area where I can barely get my hand in. Any suggestions on what to use to get the nuts off?
First soak it with Blaster or some such.
If you can get that much light and angle on it, a wobbly socket and a long extension should do it.
Wobbly sockets are more stable in a tight-fastener environment than a socket on a universal.
Is this a TR6? I've removed my rear bumper, and you'll need to soak w/PBBlaster. Then socket, short extension, CV boot type thing for sockets, (what are those called again?) then long extension....
