have VROOM again on engine rebuild, breakin check?
recordsj
Finished rebuild of engine and car drives again! We have vroom-vroom again! Now I am able to be on the road for at least most of the summer here in the pacific NW.
Should I be checking torque on the head studs after certain number of miles from the rebuild? Anything else I should look for/check?
Re: have VROOM again on engine rebuild, questions
I've heard 500 miles as a common benchmark, but get some other opinions (ideally from Hap) as well.
Thanks.
I am looking for a list of stuff to check. I figure check the valve lash, drain the oil and replace the filter,... anything else? What about checking head stud torque?
Just don't overtighten. It's easy to do. You don't want to snap a head stud at this point.
I always use a torque wrench to so over tightening is less of an issue...
500 is appropiate.
so does anyone have a list of suggestions of things to check @ 500 miles.
I already figure to check valve lash, spark plug condition, drain oil (replace oil filter), anything else? Is it a good idea to check head stud torque (or is this possibly going to cause issues, if done it would be with a torque wrench).
Timeing, brake adjustment, you know all the stuff, Might also check bolts in rear suspension for tight while you about it.
Actually 500 miles is when I recommend the first oil change, you can retorque the head and re-adjust the valve after a few heat cycles, you may find the head nuts furthest from center to be the ones that the most torque in retorque, you can do it now if you have a few heat cycles on the engine. In short, it's not miles deal, it a heat cycle deal.
